Aquatic AV and Harley clock
Hey everyone, I had the Aquatic AV radio installed in my Street Glide. Just the other day the clock in the tripometer area appeared. How do I set this sucker? I have the upper end Aquatic without satellite and clock. Thanks in advance for the replies.
Ahhh, I found it in the CVO Owners forum. I couldn't find it by search here.
Press and hold the odometer button, when the clock blinks press and let off to change hour or minutes, press and hold then let go. Not sure of exact sequence, been to long since I've done it but you'll get the idea. Logged |
i have a 2012 streetglide, and i dont see the clock on my odemeter, how do i make it appear???
it shows up when the oem head unit is changed out .
It did not do that for me... wierd
I have a 13 streetglide.it seems like it took a few ignition cycles before it came on.
Yeah, mine didn't show up right away either and then one day, there it was.
Originally Posted by EdsStreetGlide2010
(Post 16547693)
Originally Posted by Softy 103
(Post 16572737)
I don't think you have the upper end Aquatic if it is not satellite capable and has no clock.
From the 2009 Road Glide manual
Turn the ignition switch to ACC or IGNITION. 2. See Indicator Lamps: Touring Models. Press function switch until time (hour and minutes) is displayed. Press and hold the function switch for five seconds or until 12HR begins to blink in the speedometer display window. Release the button. 3. Press and release the function switch once to advance to a blinking 24HR or military style time display. Each time you press and release the button, the display will switch between 12HR and 24HR. 4. When the desired time style is displayed, press and hold the function switch for five seconds. The display will switch to the time display with the hours blinking. NOTE: There is no AM or PM time setting required. So when correct hour is reached, press and hold function switch to advance to minute setting. 5. Press and release the function switch repeatedly to advance the hours. Each time you press and release the switch, the display will advance one hour. 6. When the correct hour is displayed, press and hold the function switch for five seconds. The minutes display will start blinking. 7. Press and release the function switch repeatedly to advance the minutes display. Each time you press and release the button, the display will advance one minute. 8. When the correct minutes are displayed, press and hold the function switch for five seconds. The minutes display will stop blinking, indicating that the clock has been set. 9. Turn the ignition switch OFF. |
© 2024 MH Sub I, LLC dba Internet Brands
