my latest install is complete and ready to roll
Appreciate the responses. Really some big factor many underestimate is the design and install challenge. Having filler lights and getting the speakers in just the right spot with no room for error and finding a amp mounting concept that will leave as much usable space in the stretch recess of the bags are all a challenge. Then adding liners and working around all that is very time consuming if you're meticulous about it. As far as the 880. I really do not miss them. Great speaker, had its place and did it's job well, but the improvement from now vs then far exceeds the 880's capabilities. Also was glad to be able to give a good deal to a fellow brother here so he could also get where he wanted after some hiccups along the way. Cory Thanks and also your Welcome LOL!!!
horns
hey so I seen you have all running off of one amp how did you separate horns from full range mid bass speakers? I just ordered st 25 and 165.1 spl for up front the milli pro 165.3 for tour pak plus the 200.1 spl and st 35 horns and I am hung up on should I get a separate amp for the horns
Thanks Bert. How you been buddy? Hopefully you faired out well with Irma.
Got my bags done and all the wiring and the dsp reconfigured for new setup. Install went well and came out clean as could be. No kits here. All hand made by myself. Took some work to get all how I wanted but amp very happy with end result. Thanks to baggeraudiolab for the equipment and advice along the way. Right now the bags have so much air volume the lid speaker hits my grill when turned up so they are down -3db to keep all in check. Sounds absolutely phenomenal and after more refining will be even better. some pics and couple vids of sound after initial tune.
https://www.youtube.com/watch?v=SIg-y5agGcU
https://www.youtube.com/watch?v=-CpqFzYcDmg
Traded both bikes and purchased a 2018 SGS. I want to start fresh with new audio. I see there has been a lot of new options being used so going to need some assistance putting a package together. Going to hitting Alex up soon.
