Best speaker wire??
10-02-2017, 01:12 PM
Best speaker wire??
Wondering what is the best quality speaker wire out there? Does it even make a difference of brand as long as gauge is the same?
10-02-2017, 04:03 PM
You want to go with OFC wire. It is solid copper verses copper clad. OFC is the design not the manufacturer.
10-02-2017, 06:18 PM
Quote:
Originally Posted by
Kawickrice
Oxygen free copper I assume? What about size I believe 16 should be good enough or should I drop to 14 or even 12?
10-02-2017, 07:20 PM
16 ga was recommended to me with what I am running. I will go bigger once I change out amps pretty soon. By the way what are you running for a system?
10-02-2017, 07:50 PM
Nothing special. Kenwood kmrd368bt ,SS PN4.520 amp and jm rokker speakers 7.25 front and 5.25 rear. I got an awesome deal on them so I jumped for them. I have heard others say they suck for the money but they are way better than stock and good enough for now, till have I can afford better system. Gonna have bike all apart this winter so I want to upgrade wiring for future when tank and fairing are off. Just used a boss kit when I did initial install and read wiring makes a difference so I will change it all to good stuff
10-02-2017, 08:22 PM
10-02-2017, 08:32 PM
Thanks for the link. Makes it easier to narrow down brands when I'm given one. From what I read it sounds like stinger 4000 rca's are the best also?
10-02-2017, 09:03 PM
Gannicus
looking thru the link, is there a difference between 8 gauge speaker wire and 8 gauge power/ground wire?
10-02-2017, 09:09 PM
No. But the 8 ga speaker wire is great to use for power and ground when running it under your gas tank. It just makes it easier to just run one wire
10-02-2017, 09:13 PM
Knukoceptz.com has a good selection of wire and RCA's also!
