New FOCAL Fairing amp 4x175w!
#242
Gann...are both those 600/6's in your fairing? Would two FDPs fit in an 09 FLHTCU?
I'm thinking about PA601s in the lower pods, PRV 6MR500-NDYs in upper fairing, and not sure about the pak pods. I have stock 5.25 pak pods and havent researched if I can enlarge the hole to accommodate PA601s, or just go with BT747s.
Eventually I'm thinking SBD CCK lids...down the road a bit.
#243
I did read about Elroy, contacted him and asked if what he had for me to buy was v1 or v2 and he never replied. The posts I saw made it seem like v2 were improved and I didnt want to pull the trigger on a 50-50 shot in the dark.
Are your 600/6 Ms or XDs? Are you content with them or itching to try the FDP?
Are the tiny Hawgwired amps with side-brackets any good for just DDB3 horns? Seems two of those and an FDP would fit in the fairing
#244
The hawg wired amps are junk. I'd stay away from those. If you want to run a smaller amp for your horns I'd recommend the NVX MVPA4.
#245
Just kidding bro! I was basically saying when they come up with a 6 channel amp rated at 200 watts per channel @ 4 ohms with the same footprint as the focal amp. I'm all in!!
I presently run two JL 600/6 amps. That's it. My JL's are only 75 watts per channel though. To get 200 watts I have to bridge em. But technically I can only bridge 3 speakers. Lol!!
#246
Yes technically. In my scenario the assumption is 4 ohm speakers. If a guy was to run 8 ohm speakers that number would increase to 6 speakers bridged parallel @ 4 ohms. 200 watts per channel. So yeah. Depends on the math. Just having a little fun here brother. Bottom line is I wouldn't trade my JL amps for any amp out there but that's just me. To each his own. Now in my mind that MMATS 6150 is mighty tempting if a guy has $900 bucks laying around he's not doing anything with. . . If I were to upgrade for the 100th time. That's the amp I'd roll with.
#247
Asuming that the 6MR500-NDY (8 ohms), has the same specs than the 6MR500-NDY-4 (they show the same on paper), I don't see how the 8 ohms version is going to sound better (or at least as loud) than the 4 ohms like some claim.
#248
#249
Well but the 8 ohms speakers would be receiving 100 Watts instead of the 200 that the 4 ohms will receive.
#250
Subs? I've never had subs in my bike yet. I have the JL TW3 subs sitting on my shelf for a future build but I presently run 10" midrange speakers in the bags. But to answer your question. Yes Sir!! I still have my TN4.900 sitting on my shelf. Love that amp!
