New FOCAL Fairing amp 4x175w!
Old 01-16-2018, 07:20 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
Originally Posted by flcusat
T, do you care to elaborate on these limitations?
Thanks in adance.
Really it's about the ability to parallel speakers. Nothing more, nothing less. The ARC is constant power thus is gonna throw 150w regardless of ohm, unlike for example the HDP will throw 150x4@4 and 250x4@2.
Since I'm a guy that is not gonna put amps in my bags or TP, paralleling is always in the cards.
4 SV 165s run in parallel off channel 1/2 / A of a Hertz HDP4 will be getting 125w each.
4 SV 165s run in parallel off channel 1/2 /A of an ARC 600.4 will be getting 75w each.
ARC is a solid amp for sure, but if parallel ops is in any way in your build plan, I would not use it.
2 cents.
T.
  #342
Old 01-19-2018, 07:29 PM
wuneyewilly's Avatar
wuneyewilly
wuneyewilly is offline
Has anyone tried to register their FDP's in order to claim the hopefully imminent new cable harnesses, or warranty in general? It wont accept the model, serial, cant find the product...
  #343
Old 01-21-2018, 06:14 AM
travelingypsye's Avatar
travelingypsye
travelingypsye is offline
Hey guys running this amp, how is the fm reception with the sport? I'm not married to fm but like to listen to it at times.
  #344
Old 01-21-2018, 07:34 AM
twspalm's Avatar
twspalm
twspalm is offline
Negligible to no FM reception attenuation on mine. AM and WB comes in fine too.
  #345
Old 01-25-2018, 04:17 PM
mikes300's Avatar
mikes300
mikes300 is offline
Got it crammed into my 18 RGS, took a bit of moving wiring around, cut off the tabs on the light, and swapped out 2 allen heads holding the top of the light for some button heads, bought me about 1/4” just used some heavy Velcro right on top of the headlight
Attached Thumbnails New FOCAL Fairing amp 4x175w!-5d00e75f-2673-4aa5-8ad7-1ee108c92696.jpeg
  #346
Old 01-25-2018, 04:43 PM
kojak's Avatar
kojak
kojak is offline
Received 2,484 Likes on 1,238 Posts
Comes in fine, usually I'm on media or Sirius.
  #347
Old 01-25-2018, 05:05 PM
Outkast6991's Avatar
Outkast6991
Outkast6991 is offline
Would it fit the other way (sideways)? Looks like it's longer than wide
  #348
Old 01-25-2018, 05:43 PM
mikes300's Avatar
mikes300
mikes300 is offline
No I tried that too, it would actually fit perfect if it were square, it’s to wide to fit between the fairing braces, ideally it would be the same square inches but square with the dials in one side and connection on the other, but as it was it’s pretty easy to get in there, sounds awesome! And I haven’t flashed it yet, getting that tomorrow, so all I have are the 2 front speakers.
  #349
Old 01-25-2018, 05:50 PM
mikes300's Avatar
mikes300
mikes300 is offline
See if this link works, need to get the lids working, and more tuning, but for a first go I’m very happy, Polk MM 652’s
  #350
Old 01-28-2018, 09:07 PM
FXDFan's Avatar
FXDFan
FXDFan is offline
So after reading all 35 pages, being I'm an audio neophyte, is this Focal amp good to go for a '13 CVO?
Have a set of Focal KRX 165 in the fairing, and a set of Focal KRC165 on the shelf I'd like to run in the lowers...
Be a combo worth pursuing? Or other / better options out there?
Quick Reply: New FOCAL Fairing amp 4x175w!
