Length of RCAs? HU to tour pack 08 Batwing Ultra
BlackPearl#1 (10-16-2017)
I used a Krystal Knukonceptz 2m RCA... was just long enough to make it to my TP! I got the RCA ends into the Tp with maybe 2 inches to spare, then plugged the RCA ends into the Y splitter (1 female to 2 male) perfect...lol ..... Kris if you look at the pic's you posted of my amp install u can see in the 1st pic ( right side of amp) how much cable is showing...not much...inch on one 2 inches on the other!
BlackPearl#1 (10-17-2017)
putting the 6 footer behind the side cover makes it simple for a quick disconnect...or at least the easiest possible quick disconnect. Its entirely possible that you dont' remove your TP so in that case of course, you can run one directly to the amp. Running the 6 to the side cover is the easiest quick disconnect if you were putting an amp in the bag, which would need to be removable. Just another option!
Kris
Dave Grayson
Screamin Eagle CVO Models
06-16-2014 02:56 PM
