Lol...I questioned this very thing.
As a very knowledgeable individual told me..."I can't explain the science of it, but listen for yourself." I heard this all first hand before I went this route, I wouldn't change a thing now that I've gone to 8 ohm....my .02
Are we talking about the same MMats speaker that yooperhog referenced above or another brand?
Have two pair PRV's in hand and purchased a bench grinder. From what I understand the PRV's will line up with the BT speaker brackets using the BT 7.1 holes without any mods. The other pair will be going in the lowers. The question I have for those that have modified these speakers, do you drill new holes into the gasket area of the speaker or elongate the existing holes? I'm using clip nuts and bolts to hold them in with these grills.
The PRV's for the lowers are now round. Not fun grinding the aluminum baskets but they should be well worth it. The screw clips I was using with the SV's won't work with the PRV's do to the size of the basket. So I had to order more stock captive nuts to mount them.
