ARC PSM and Fosgate DSR1
DSR 1 pros: it has 8 outputs and is able to use Bluetooth to a phone or tablet to control things instead of a computer only and cost. Haze has some play time with it and will likely have more info than that. Only down side i see is the size for trying to cram into a fairing.
In a nutshell:
ARC - better sound quality, smaller, better build, only 6 channels, expensive
Fosgate - bigger, lesser build quality, has 8 channels, less expensive
Between those, folks just need to weight out what's most important to them.....size, sound quality, channels, budget.
That are small enough to hide in a fairing along with an amp --- not many, that's why the Arc has been such a hit. Now other companies with decently sized DSP's, theres tons of those: JL Audio, Mosconi, Helix, DD Audio, etc.
I have the Rockford Fosgate 3SIXTY.3 processor. Granted you need room for this DSP (I have a '15 Ultra Limited) and it's pricey. I have it mounted in my Tour Pak. I previously had the JL Audio FiX86 which worked well, however was limited to 4 channels of processing and the EQ was pretty basic. When I added saddlebag speaker lids (6 speakers total) I needed something more. I liked that the FiX86 had an automatic normalization function to fix the crappy Boom HU's EQ output. The 360.3 has a simpler function which I think works better than the Fix86, plus it has a 8 channel interactive signal processor w/248 band parametric EQ! This thing is a beast! If I ever add lower fairing speakers (8 speakers total), I won't have to upgrade again.
HogPilot54 (11-28-2017)
In a nutshell:
I’m curious as to why you feel the build quality is less than the PSM.
