If your thinking that you would bridge the PN4 520 to get the 260 rms x 2...you could only use the 4 ohm speaker which is the Polk mm652...Infinitys are 2 ohm , 520 is only stable bridged at 4 ohm's I think!! AD CX 62's will also work!
Very true. Sorry about that. The soundstream pn2.350d would be great for kappas. Pn4.520d would work for everything else
If you are going to add an amp and speakers, do it right. Not massive show quality but right so you can hear it at 70-80. Polk mm series, infinity Kappas I know will fit. DB Design Motos are great but I'm not sure they will fit in the pods without modifications. Cerwin Vega b-52 will do those or any speaker justice.
Here you go:
B-52 amp- $135
Polk mm 652- $150 or kappas about the same price.
Biketronics bt355 LL- $80
Mis. wiring and connectors- $25.
Total- $390 based on amazon pricing. Can be had cheaper.
This is just one option that is proven and will sound good.
I just did this with the Kappas, and came in around $320-330. I also used the Hogtunes amp tray, I think it was $30. I find that I'm not turning the volume ALL the way up when I'm on the freeway. So far I'm pretty happy with it.
