RF amp and Hogtunes Gen 3 6.5s installed
Installed them the other night. Sounds good to me and definitely sounds way better than stock.
Used hogtunes gen 3 6.5s and RF PBR300x4. Sounds pretty good even at 80mph on the freeway. I'll be adding 6x9s in the lids hopefully this weekend.
Have a RF T400x4 on it's way. Decided to switch simply for the cooling fans. Wiring is not my strong point so I went with RF's wiring kit and amp mount. Worth the price to me.
So far, didn't break the bank, but I wasn't going for a show stopping stereo to begin with. Just enough to be able to hear the music clearly since I don't wear my hearing aids while riding.
Update to this.
Quickly blew one of the Hogtunes speakers. They were easy to deal with and replaced it. Just re-installed the speaker up front. I switched to the TM400x4 amp, barely have the gain up, and the system is quite loud. I added some Kicker 6x9s to the lids. All around, I am very pleased.
Now can someone tell me if a reflash is a must? Can't seem to get a solid answer on this.
You can't run aftermarket audio on a Rushmore without a BT355 or some sort of DSP. Next time it'll be your amp that goes up in smoke. And make sure your AVC is off.
http://www.biketronics.com/bt355-hd-...r-2014-and-up/
Originally Posted by Stroked16
Ok. There’s three options, and I am clinically retarded.
I have after market amp, front speakers and added rear speakers. I can only select either front connector or rear. Does this mean I need two?
i really appreciate your help.
