Budget amp & Speakers
Respectfully, you dont want that Rockford 300x4 amp.. Not gonna accomplish your goals. Its not recommended on this forum EVER. If you were super worried about retaining FM I would go with the PBR 300x2 amp and only AMP the fairing Kappas. Just run the rear Kappas off your deck.
I have run the Kappas in the fairing and a PBR300x2 amp for many many miles before I upgrades to PA. I highly recommend them both.
If you can let FM go, do the B54 and 4 kappas!!!
There is another alternative that doesn't loose fm and with the kappa's it will sound good. The rf tm400xad is rated 100w x4 but is always under rated. I also know that it doesn't loose fm even sitting on top of the radio. There are some here that wont run it but the experience I have had with it has been good and the ones I have installed are more powerful than they are rated.
Glad you guys are here for guidance.
I'm sure I'll just do a 4 speaker system, whether it be fairing/tour pack or fairing/lowers.
I must of misunderstood, I thoughtI could run 4 infinity 62.11i speakers with a b54? Aren't they 2 ohms?
What amp would I need to run 4 infinity 62.11i speakers?
you guys have been a wealth of knowledge.
https://www.advanblack.com/harley-pa...flhx-fltr.html
The color was off a little bit on mine so I called them and they are sending another set free of charge.
