What will i lose with a boom pre-cal reset?
I would assume that I will lose any audio settings. Will I need to re-install the latest Boom software update? Will it remove saved routes in the Nav section? Will it remove my dealer flashes for passing lights with HiBeam, WHIM and PTT move?
I will reset it regardless but need to know if I need to schedule with the dealer for flashes. My time with my bike this trip to OR will be pretty short.
Thanks,
Dave
Thanks,
Dave
Hey brother, no you won’t lose any dealer flashes that pertain to lights. The only thing you will lose are YOUR entered settings. So basically anything YOU have saved/input/set will be lost. If you have a lot of routes in the radio you can go in the setting (navigation) and export them all to a usb stick. After reset you can reinstall them.
The flashes the dealer installs are a different level of programming that unless you have the equipment, you can’t alter/change/ mess up.
so reset away...
so reset away...
so reset away...
so reset away...
