Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Audio Systems (https://www.hdforums.com/forum/audio-systems-153/)
-   -   JL MX500/4 clipping (https://www.hdforums.com/forum/audio-systems/1232126-jl-mx500-4-clipping.html)
HD_Doobie 05-06-2018 04:49 PM
JL MX500/4 clipping
Last fall I Installed a JL MX500/4 bridged with DD AW 6.5 and AT28's I bought from Alex. I tuned it with a 1000hz -5db test tone, 3 bars from max, engine running, set to 28 Volts AC. When I get just over half volume usually the right, but sometimes the left speaker will cut out for a few seconds and then come back on a few more seconds later. Or if I turned it down a notch it will come back on. I assumed the amp was going into protect mode. Pulled the fairing and adjusted to 25 volts. same issue just a little higher up the volume bar. Finally turned all the way down to 20 volts AC and same issue. Again just a little higher up the volume bar.
I have 8 ga. positive and negative to the battery. I am 100% sure AVC is off. I am getting zero distortion. Why is this amp clipping so easily? Technically I should be able to have this set at 31.6 Volts, right?
What else can I check?? Thanks,
Juice 05-07-2018 10:37 AM
That amp bridged is only stable at 4 ohms. How do you have the speakers wired?
haze324 05-07-2018 12:01 PM
a few things can cause clipping....distortion, drop in voltage that can be caused by a bad ground, bad fuse, weak battery (yes even while running), or sometimes a crossed wire. I know some of the TXO's last year had the + - reversed on the color scheme. That could be it too.
HD_Doobie 05-07-2018 04:48 PM
The tweeters and mids are in parallel. I will attach a picture.
HD_Doobie 05-07-2018 04:53 PM
Battery is brand new this year. 600CCA Throttle X. I have 14 volts steady to the amp when stereo is cranked, idleing. Even revved above 2000 RPM and it stays steady at 14 volts. I will triple check the TXO's for wiring. The dashed line is positive on mine.
20 volts AC at 3/4 volume seems awfully low to be having cut out issues, don't you think?
Going to pull the fairing now and check things. Will post some pics after.
InthewindMN 05-07-2018 05:10 PM
What year/model bike is it?
HD_Doobie 05-07-2018 05:18 PM
2014 Street Glide
InthewindMN 05-07-2018 05:35 PM
Originally Posted by HD_Doobie (Post 17340643)
2014 Street Glide
pods or BT brackets? Line leveler?
HD_Doobie 05-07-2018 05:43 PM
BT brackets and BT line leveler.
HD_Doobie 05-07-2018 05:45 PM
Here are some pictures of my connections.
https://cimg5.ibsrv.net/gimg/www.hdf...dede9c7b24.jpg
https://cimg4.ibsrv.net/gimg/www.hdf...3d118da7bf.jpg
https://cimg3.ibsrv.net/gimg/www.hdf...d0f1b61c01.jpg
https://cimg6.ibsrv.net/gimg/www.hdf...144acfcc0e.jpg
https://cimg7.ibsrv.net/gimg/www.hdf...f33d0385cf.jpg
© 2024 MH Sub I, LLC dba Internet Brands
