Trimming the PRV 6MR500-NDY for lower fairing
Is there an efficient way of trimming the PRV 6MR500-NDY to fit Lower Fairings? I have searched and read through a few posts discussing the speakers and the trimming process. Apparently, there are a few ways of trimming the square basket to make them "round" for lower fairings. I just want to do it right and not destroy them in the process.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
sent you a PM
I have Beymas and they too have a square flange,
1) tape them up to cover the basket to not allow anything to get into the voice coil and speaker. I used a couple layers of newspaper and a good masking tape.
2) scribe a line to give yourself a line to grind to
3) I used a stationary grinding wheel and ground down the corners. I was able to control the amount coming off and the heat build up and made it as close to circular as I could
4) use a small drill bit to drill a "guide" hole for a larger bit that will allow the size screw you decide to use.
5) make sure the speaker is completely clean before you remove the tape and paper.
It took me about a 45 minutes to do both speakers. Its not hard to do. It is just one of those things, when you start, you have to see it through to the end!
Take your time and it will be fine.
Carson I’ve always used a speaker grill back for a 6.5. Just lay it over the speaker from the back and center it up and draw your cut marks. Cut with a jigsaw, clean up with a sanding disk. Then use the same speaker grill backing which should now fit around the speaker properly to mark your holes for drilling.
And mask the living hell out of the guts of the speaker or it won't last very long. Keep an eye on the heat generated when cutting as to not get too damn hot. It's about 3 beers per speakers vs the anticipated 1 beer per speaker.
T
I bolted the stock Harley speaker to mine worked well. I rounded all 4 of my 6mr500s. I prefer the flap disc to the jig saw or bench grinder. The bench grinder loads of fast and the jig saw was just awkward as hell for me. As with most things there are a bunch of ways to get it done. Just offering my experience.
