PRV 6mb250-NDY
We use them all the time. Good midbass, decent vocal but not the upper frequency range the MR500’s have. I really think these benefit from a processor where you can cut the high freqs off otherwise the roll off doesn’t sound too clean in the upper range. They really shine in the lower midrange so you'll want to some strong highs, to fill that gap.
Originally Posted by Delgado130
Has anyone tried these speakers? I know most guys are running the higher end model but the specs are not bad for this model.
T
Originally Posted by Babyboy
I am running them in my tourpack pods paired up with a set of DD T2 tweeters and fill in real nice on my system.
I am going to put a set in my lowers (14 on my wethead)as soon as time allows.
Does the Crescendo Ultra Neo fit in those tight spots?
I have the oversized e-glide pods and them biatches fit damn near everything, so have not had the need to try these in the TP Pods.
T
I am currently running mmats in fairing. DD horns. american bass 6.5`s in lowers. Polk mm692 in lids. Everything is running off a pn4.1000d at 2ohms. I plan on purchasing another set of polks and mount in bags facing wheel. I would need to add another amp or switch out the mmats and AB for 8ohm Prv`s in order to run just one amp.
So it's a speaker that is on a short list of speakers used to fit in small enclosures? And u prob would never use it in fairing, non-wet lowers or June's pods?
T
T
I did a install for buddy on his bike with 4 of the PRV 6MB250NDY a set of DD T2 tweeters ,linelevler and a Diamond 4v2.
Here is a video of the setup.
https://www.dropbox.com/s/sm9dumksps...51346.mp4?dl=0
We use them all the time in the fairing, regular lowers, etc., and no UN's don't fit.
Actually funny you should ask that question T about using these speakers in the stock pods on a batwing.
T
