2 x TM400X4AD under fairing in 2018 SGS?
i would say that you could if you were using the BT speaker brackets, as they free up a lot of room. the amp is not that big especially if you do not use their glorified amp tray stuff.
m
ps, i have not done this install, i am basing my opinion on the other 2014 bikes that i have done, if the underhood of an 18 is THAT different, well. take thin cardboard and cut it and tape it up to the dimensions that they list online for the amp, and use it like a dummy to mock it up and see if it seems like it will work out.
m
Funny you ask that as I am working on exacty that same project. I am researching amperage draw from the amp vs. amperage output from the stock HD charging system so not to zapp the amps from under amperage. 13-15 volts are one thing but proper amperage to the amplifier is a must.
i am currently running 2 RFTM400x4ads and an ARC Moto600.4 on my bike with the upgraded 50amp Cycle Electric Charging system kit and I am not running into low voltage issues unless it's at high volume at idle for a couple of minutes. at speed all is good.
m
newer bikes that have the 60 amp system should not have an issue at speed, the length of time at idle and volume level at idle are where i have to be careful.
m
m
m
Then again, none of this is proven or standard practice so for anyone else to try, I would run it past the proving board first.
The amperage is drawn from the battery, not the regulator or stator for that matter. How much draw your battery can handle and how well it can be charged becomes the issue. If I remember correctly the RF amps have an average draw of somewhere around 28 amps. No single stock battery is going to hold up at load for long. At speed the charging system is sending power back to the battery so that it can recover/recharge, but that is limited by what the stator can produce, not much to do with the the regulator. The regulator's job is just to convert the AC voltage to DC voltage and send it back to the battery at a set voltage limitm
Moto Mike (07-28-2018)
