Subs vs woofers for saddlebags?
I'm thinking of adding 8 inch speakers in my bags, what's the best way to go subs or woofers...and why! What is the advantages of using subs compared to using woofers, and what make of speakers are guys using to get the best results! Thinking if I do subs I could build sealed enclosure in bags to separate the subs from the 6x9's in my lids, or is that necessary! Also cut the hole or use drilled grid method! Any thoughts from the bass heads!
Yeah Matt, built a few sealed bass enclosures through the years, always to manufacturer specs... going to be a little harder in the back corner of the bag...thinking 1/2 MDF! I talked to DD about their 500 Series subs 506D requires .25 min. 508C requires .35 min. running off the back 2 channels of the SS TN 900. Just starting to research this!
You can get get all the bass you need from a midbass 10 if it’s the right speaker! Subs = Too much work! Lol!
Moto Mike (08-02-2018)
