18 ultra drop in speakers?
Old 08-21-2018, 11:21 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
Originally Posted by Wmbailey5
I appreciate ur perspective and to each their own. ur reply supports my point that there is more than one way to solve your equipment and sound needs. Keep reading but one day you need to land the plane and put a system in ur sled. If you don’t like it you can always replace it.
Well u really don't need to land the plane regarding sled audio because a plane will run out of gas and crash, but with sled audio there is absolutely no need to rush into a system.
Glad you like your system as that all that matters for you but without debate, info exchange, testing assumptions, and also differing opinions we become pretty damn sheepish.
T.
Old 08-22-2018, 12:46 AM
travelingypsye's Avatar
travelingypsye
travelingypsye is offline
I just put the RF complete system on my 2017 Limited. TM400X4AD amp, RFKHD wiring harness which includes tour pack and the TS 65 speakers in fairing and TP.
Everything fits and is plug and play with no cutting wires or drilling or modifications. Took just under three hours. Worst part was getting the fairing pods out and then back in.
Sound is is better than OEM at cruising speeds. Sound is very loud And clear. You don’t have the base or thump and really won’t unless you get a sub and then you lose a saddle bag.
Downside- u lose fade function and treble/bass settings are gone.
I did the install myself for $1,000 and had flashed. I wanted better sound within a budget and that is what I have.
You can upgrade for less Or pay more for a much better system. There are great people on the HD Forum that can weigh in and provide great advice.
How did you have the hu flashed? Depending on that you can get your fade control back.
Old 08-22-2018, 06:55 AM
Wmbailey5's Avatar
Wmbailey5
Wmbailey5 is offline
Flashed radio front pod and rear pod with 1 amp.
Old 08-22-2018, 07:11 AM
travelingypsye
Then you should have fade control on the head unit. Do you?
Old 08-22-2018, 07:15 AM
Wmbailey5's Avatar
Wmbailey5
It appears in the HU but cannot be adjusted.
Old 08-22-2018, 07:18 AM
travelingypsye
So it is on the hu but cant adjust or move. Is it set in the middle or all the way to the front?
mmarkfa
Audio Systems
04-02-2019 09:47 AM
RetAF
Audio Systems
08-03-2018 06:40 PM
mmacfn
Audio Systems
05-09-2017 06:30 PM
benson1603
Audio Systems
05-23-2013 11:51 PM
Sincecrazy
12-03-2008 01:15 PM
Quick Reply: 18 ultra drop in speakers?
