Where should I correctly install the Amp remote remote wire.
For the key on switch can I use the picture below, it is called, add a circuit, This is what I have my remote wire connected to, in the ACC fuse holder slot, with an additional 15 amp fuse. So two 15 amp fuses in this circuit. Would this cause an issue, or should I just splice into a key on switch wire, preferably the ACC wire in the back of the fuse block.
