Bracket options for 8" in bags
H&H have nice 10" speedrings. I haven't used their 8's but they're basically the same thing.
I would chose the H&H over the AHB ones. AHB is overly complicated and cuts off 1/3 of the speaker with their mount design. Also, they use pressfit nuts which end up spinning leaving you with the unfortunate task of using a sawzall to get your speaker out.
Originally Posted by Juice
Mike,
Try it with a drilled pattern before cutting a 8" hole. We think it acts a little like a old school band pass box. Plus, once you cut a 8 inch hole it is hard to go back.
Hit up Tailwind, he may have some advise for you as well.
Go with the hole pattern first. Keep adding holes if needed. Super 77 spray inside the bag and stick some treated grill cloth over the holes. Home made bracket is simple and a shix load cheaper.
T
I’m curious cause I bought some Outerwears prefilter material for my 6x9’s is this going to be Ok to use or should I use something different?
Thanks,
Originally Posted by screaminyz
When you guys say treated grill cloth what are you guys using? Which cloth? Which waterproof spray?
Thanks,
Thanks,
T
The following 2 users liked this post by haze324:
Johnny Goodlife (09-24-2018),
ssmorga78 (09-21-2018)
