Bracket options for 8" in bags
I'm trying to plan out best way to mount 8" speakers in back corner (or front i guess is option) of saddlebags,facing wheel. I see the American Hardbags ones and they really look like a nice setup with grills,etc...but they are $379 for a pair of brackets.
Would just using a spacer, say 1/2" and bolting speaker to bag be rigid enough? I just dont see many options when i google.
Obviously, when i mount these things and cut holes,etc..I want to make sure it's done correctly and not have issues,etc.
thanks
I think the back corner would be best or i suppose all the way to front of bag.. Just want to maximize remaining space.
thanks
thanks
thanks
What you got going now? LOL
Just like apes, if you want 8's go with 10's. alway go bigger than what you think. Otherwise, you will always question your choice.
I have heard the Cresendo 10's mid-bass and they rock.
I am interested in this also. I am thinking of making a 1/2 inch wood "plate" that fits in the rear corner of the bags and attaching the speaker to the plate and then securing the speaker and wood support plate to the bag from the outside of the bag with 4 screws or carriage bolts or a combination of both! If possible, a threaded insert (molly) of some sort imbedded in the wood plate that you could screw a carriage bolt into, and that was secure would be ideal, but I don't know if something like that exists! Most of the installs I have seen use wood rings, with carriage bolts going thru the bags from the outside that go thru the wood ring and also the speaker frame to hold securely. Hard to thread and secure the bottom bolts that way, that's why I was trying to figure out a way to secure the plate with speaker already attached from the outside of the bag! Going to Menards or Home depot to check out what type of materials I could use?? Thought from guys that have already done this??
MM, i thought about doing same, but using 3/8" nylon ,etc instead. Router everything like wood. Then seal a piece of prefilter material to keep water out.
My dads company specialized in fabricating all kinds of parts for bottling industry with various plastics. He is since gone and company sold...otherwise his guys could have made me anything. It was nice when i was younger, had access to all machines to make anything.
Im gonna check with him about getting some nylon or similar...see if he knows where.
Easy to pay $100 for a set and be done, but $379 just doesnt make sense.
lol.. I know...i know... but i think i will need a little boom boom to fill things in. Nothing crazy needed but 8s will fit better than 10s. I hate even giving space up in bags...but..
Try it with a drilled pattern before cutting a 8" hole. We think it acts a little like a old school band pass box. Plus, once you cut a 8 inch hole it is hard to go back.
Hit up Tailwind, he may have some advise for you as well.
Tailwind has been a big help to me already... as well as many others here!
This system better rock when im done...
The drilled hole pattern is intriguing, especially since I heard Juice's 6x9's. I think the only way to tell if it works is to do 1 bag one way (drilled) and the other bag the other way (hole) and hear the difference, and I don't think anybody is going to do that! My thought is if the drilled pattern really works (less air movement with drilled pattern) some speaker designer somewhere at some company in the history of speaker design...WOULD HAVE FIGURED THIS MIRACLE OUT LONG AGO, I have my doubts that's all I'm saying! Please flame away my $.02
i made speaker rings out of 1/2 inch Starboard Plastic, no rust no moisture, no rot. blend a bit with a flapper roll, mount in rear corner of the bag, treated speaker cloth layered between the ring and the hole cut in the bag., 4 fasnters though the bag, ring and speaker. mounts firm and so far no water intrusion. worked way better than i though it would. just remember to measure and size things up 2x and cut 1x.
marco
marco
