Harmon Kardon died
I've had good luck with their service. While it is there you might want to have them add front and rear preamp outputs. It makes adding an amp dead simple, just like an aftermarket unit. I did that and am able to expand my system as I see fit and I still kept all the Harley specific functions such as CB, AVC, weather band, and intercom.
I suggest you also get their backlight conversion if you do any riding at night.
Here is my radio with their white backlight conversion.
https://www.hdforums.com/forum/touri...l#post13509233
I'll chime in a little info about my experience with the preamp outputs IC added.
I got one of those Rockford Fosgate TM400x4ad amps that has the detailed adjustment procedure with the CD to set input and output levels. They say to put the CD in and pick a track and turn up the volume on the head unit until the light comes on (with speakers unplugged). The light indicates the input signal is clipping. I was able to turn the volume all the way up before the light came on. I mean one notch from wide open and the signal was still clean.
If someone wants all the bells and whistles then I can understand getting an aftermarket head unit, but since these things play MP3 CDs I don't really miss bluetooth and things such as that. If I really want to listen to my phone I have a RAM mount for it and can just plug it in. If someone wants the thumb controls to work with Bluetooth you can buy a SaddleTramp module and it will mate to your phone and you can control the tracks from the bars.
All in all I really am pleased with the sound I have with still being able to keep the stock look and functionality. Unless someone pulls the fairing or looks in the clutch side bag things really don't look to be modified much at all, but when you crank it up it will get as loud as you can stand at any speed.
I should also note that the clean low level signal allows AVC to work just fine. I live in the country and travel a lot of twisty back roads where speeds range from 35 to 55 constantly. I keep AVC set on the fourth notch and it works great. The thing is with AVC on these old HK head units it stops turning up the volume at about 50 mph, so if I get off on a major highway with higher speed limits I don't have to worry about it getting too loud. I don't know if it would work this well with the speaker level outputs and an amp as I have never tried it.
Thanks
So you’re only getting 25k from each repair? That’s not impressive!
