Adding Tour-pak Speakers - Infinity Kappa 62.11
I have a couple of Kappa 62.11 in my garage and was thinking about adding speaker pods to the King Tour-pak on my 2014 SG. Currently I have Kappa's in the fairing pods with a PBR300x2 amp running them off the stock Boom 6.5 infotainment system. So, if I add the pods and Kappa's, should I just get a second PBR300x2 or is there a good 4 channel amp that would sufficiently power these speakers. Truthfully, I am not 100% happy with the RF amp so may take this opportunity to upgrade.
Thoughts? |
Thoughts? |
Originally Posted by SBates08
(Post 17699379)
Not to stir the pot but I'm pretty sure we all told you you'd be less than impressed with that amp a while back. Regardless....The Kappas will work in the TP pods but will require a spacer to fit. I wouldn't use another PBR amp for the rears. I'd upgrade to a good 4ch to push it all. What kinda budget are we looking at and are you using the BT355 Line Leveler?
I haven't bought them yet so will get something else if needed but thought that the upgraded pods would fit the 6 1/2" Kappas. https://www.harley-davidson.com/stor...-enclosure-kit Tour-Pak® Rear Speaker Enclosures enable the installation of Boom!™ Audio 6.5" Rear Speakers on Street Glide® and Road Glide® models equipped with King Tour-Pak® Luggage. |
Obviously clarity is an issue but consider that I don't sit parked listening to this radio. I am usually on the road going about 60-80mph with ear plugs in and a full helmet. I am not looking for the clarity one would expect in a high end automobile. I need something that can get past the wind, exhaust, ear plugs and helmet and not sound like shart in the process.
I think this would be a great amp and will be one you can grow with.
https://m.soundoftristate.com/item/3134353634 |
Bates, have you tinkered with one of those stinger amps before? On paper it looks pretty good. At some point I am thinking of moving the RF TM400x4ad out of the bag and into the fairing and the amp you just listed looks to have similar specs, but I am wondering if it would be as powerful as the RF in actual usage.
I love the sound of the RF, but it is the hottest running amp I have ever encountered. I am thinking of replacing the SS in the fairing to regain some FM reception and wondered it it would run cooler in the fairing where it might possibly get some airflow. |
© 2024 MH Sub I, LLC dba Internet Brands
