Going to 3 amps.....let’s talk batteries
I’m in the process of adding two more amps to my set-up (will have 3 total). What are you guys with multiple amps running that will help extend run times in the parking lot?? I’ve read a little not on sealed and lithium but thought I would reach out to the experts on here. Thoughts??
You know it's funny I am just getting to the point where I need a new battery for m 2010 Ultra Classic. I have two amps now and may add a spall third one down the road. I'm not worried about parking lot runtime at all (nobody around here but me to listen to it) but I was wondering if there was a better battery for longevity and/or cold cranking amps than the Harley branded AGM battery (I have heard good things about it).
Do the Braille batteries offer better CCA or just run time? I figured I'd ask around before buying.
The Braille 3121 is awesome. It the amp hours that folks are worried about with respect to music. CCA is likely comparable to other similar batteries it's size. I'm not too smart on the CCA and requirements to turn the motor over, my knowledge is more on power draw, amp hours, etc for audio...but with a slower draw, your voltage remains higher and easier to start the bikes. That's my math!! I ran three amps off one battery for a while no issues. You guys aren't running three amps to push 12 inch subs that will require MUCH more juice then lets say a few 6.5's, horns, and a set of 6X9's.
The following 2 users liked this post by haze324:
Hoyt 1911A1 (10-18-2018),
Lucky 7 Custom Cycles (10-18-2018)
