Review: Best 2 Speaker set up Battle of the Pro Audio Coax
Great review and thank you.
Since the Beyma 6CX200DNd is to deep to fit in the 14+ batwing is there a Beyma mid driver with similar specs as the mid driver on the 6cx200dnd that us batwing owners could use with a seperate horn tweeter?
Thanks again for the testing and reviews
Beyma DOES have a comparable woofer but the reason why this coax works is because the "horn" is really a compression driver with a vocal range and not a tweeter. So if the woofer falls off in the vocal range, your DD B3 is not going to play low enough to pick up where the woofer drops off....hence the use of a compression driver. The Faital would be a better option that has a woofer that plays higher in the freq range.
Originally Posted by travelingypsye
I can attest that the beyma's wont fit in the fairing with the brackets. They are about 1/2 to 3/4 inch too long and the top outer corner hit the outer fairing when mounted on the bt brackets.
Always fun to read these reviews. Definitely appreciate the time and effort to post these.
You mentioned it will take quite a bit more power than the PRV to be as loud. Do you feel the SD800.4 was enough power for the Beyma? I'm assuming this is a bridged wiring configuration?
Zach
Zach
Bluesman280 (02-13-2022)
I posted while back a review on the GZ pro audio speakers with a horn mounted in the back. They have fantastic vocals but no low end. The surround is a flat foam, I think I had to cross them around 200hz. The sound great, but not ideal for a 2 speaker fairing set up. Maybe lowers or another location if the bike had tons of bass to keep up.
