Rockford Fosgate
  #71
Old 01-16-2019, 08:54 PM
marshallb's Avatar
marshallb
marshallb is offline
Originally Posted by Hoyt 1911A1
The ratings on the RF amp are intentionally conservative. The amp is advertised as constant power:
100 Watts x 4 @ 4-Ohm
100 Watts x 4 @ 2-Ohm
200 Watts x 2 @ 4-Ohm Bridged
But they also list a "dynamic" rating:
128 Watts x 4 @ 4-Ohm
152 Watts x 4 @ 2-Ohm
290 Watts x 2 @ 4-Ohm Bridged
I recall the test sheet on my amp rated all four channels at a minimum of 140 watts at 2 ohms @ 1% THD.
So are you saying it's a 560W amp or a 608W amp? It's kind of confusing.
  #72
Old 01-16-2019, 09:30 PM
InthewindMN's Avatar
InthewindMN
InthewindMN is offline
Are the test results dynamic or rms? Dynamic is basically peak output.
  #73
Old 01-16-2019, 09:40 PM
marcodarq's Avatar
marcodarq
marcodarq is offline
The amp is 400 watts. The birthsheet that comes with each unit is the factory output test result for that specific unit. They areca little underated, but not an issue. As mentioned previously, if you use speaker level inputs they will get louder than low level input. The amp is a very good unit if 100 watts per channel, or the 200 watts bridged fits your overall build design.
m
  #74
Tailwind's Avatar
Tailwind
Tailwind is offline
T
  #75
Old 01-17-2019, 08:42 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Hoyt 1911A1 is offline
I don't know all the ins and outs of this stuff but here is a copy of the info they send with the amp: Given this it seems that a lower impedance speaker MAY play a little louder than a 4 ohm speaker of similar design.
  #76
Old 01-17-2019, 11:37 AM
Tailwind's Avatar
Tailwind
Tailwind is offline
Point being is that dynamic number just gives the amp consumer the warm and fuzzy, bit u sure as hell don't want to build ur system around it.
T
dmax3311
Audio Systems
30
04-28-2017 02:04 PM
brinks13081
11-06-2014 08:35 AM
harley_guy1995
01-20-2013 09:31 PM
drz400222
03-10-2011 10:25 PM
Harleypingman
04-28-2010 11:41 PM
Quick Reply: Rockford Fosgate
