Audio System Wiring Diagram
Originally Posted by drumdon
No. Why? I'm assuming you're asking because it's not equipment that's up to the "caliber" you'd recommend (I see that you're in the "custom audio" business). I did a ton of research on the components I got, so I'm confident in their reliability and output...and honestly that's what I could afford. I had similar components on my previous FLHR and was very happy with them and the sound they produced. I'm not on this forum to keep you in business. I simply asked the question about the diagram and if it looks like it would work.
Thanks.
Thanks.
This is why I hate replying to threads like this because the OP always thinks the worst when you start asking questions. I'm not here to burst your bubble. In fact it's quite the opposite. But you've done a ton of research so you'll be ok.
I will however tell you the amp is garbage. You'd be money ahead to send it back and purchase the Cerwin Vega B52 amp. Parallel the left side speakers together as well as the right side. This gives you 2 channels at 2ohms and 125 watts to each speaker. The Stealth states it does 90 watts at 4ohms but it doesn't come close to that. Good luck.
smlosches@yahoo.com
Audio Systems
14
11-15-2018 08:15 PM
