What kind of lugs/crimps or soilder?
What are you guys using for the terminal end for a distribution block, fuse block, or terminated end going into Sound Digital amp?
Looking for 4 Gauge and 8 gauge specifically.
Juice
Once l have the insulation stripped from the end of my power supply line, l use a portable mapp gas torch to solder the exposed wire. Makes for a good solid connection when tightening the set screws in the amp/distribution block.
I just picked up some of this deadener as well for inside my fairing in a few spots. Should I also line the inside of my lower fiberglass speaker pods or leave them as is, or add that batting material?
I didn't know if deadener in the pods would affect the already little midbass I have by absorbing it or if leaving hard surfaces inside would be better. F if I know haha
