Not yet. I’ll be able to get the fairing off this weekend to play around with it
I hooked mine up this week and honestly if they are not in their desired range they do not sound good at all. (not a plug and play scenario) I then put them in their "sand box" yesterday and they really came to life. I still have a lot of tuning to do.
I Just band pass the woofer from 70-2650hz 12bd slope and set the horn from 2600+. These are not the ideal/Best area but just to get some power to them and to keep them from running wide open. Night and day difference.
And what are all them wires going into the driver terminals?
T
The world may never know.. No, I just found it easier to run the lowers parallel from there than back to the amp, Plus that little SD250 does not have a very big slot for 2 sets of speaker wire at the terminal ends.
Juice
Are you running the 6cx compression drivers parallel with each other or a set of lower horns/tweeters with them.?
Juice
I did the same thing on my 250.2. Ran one 12g wire from terminals to fairing, then soldered a split of 14 to go to each driver. Those 250 terminals are tiny.
