Speaker set up in street glide
Old 03-22-2019, 01:07 AM
Baggergee's Avatar
Baggergee
Baggergee is offline
6th Gear
Default Speaker set up in street glide
Okay, I知 new to the group and stereo systems on Harley痴 but thinking of this set up. Looking for some opinions. So I知 thinking of running Hertz speaker set up as follows
soundigital 1200.4 Evo amp
hertz MPX 165.3 fairing
SPL 200.1 lids
ST35 lids
SPL 200L bags
thoughts??
Old 03-22-2019, 09:21 AM
Juice's Avatar
Juice
Juice is offline
I don't think that amp will push all of what you have. even with fun wiring options. you need more channels. The SPL200 will take more than 2 channel can give right off the bat.
Juice
Old 03-22-2019, 11:31 AM
Baggergee's Avatar
Baggergee
6th Gear
Thanks Juice, I am actually running the Rockford T400x4ad amp now and was just talking with a guy about just adding another one of them. should give me plenty of power then, I'm thinking.
Old 03-22-2019, 12:17 PM
Juice's Avatar
Juice
Juice is offline
That RF am puts out the same in 4 ohm or 2 ohm and would not be enough to push those 8 inch Hertz well. I would rethink that amp! And with the choice of speakers given, a DSP would definitely be needed.
Juice
Old 03-27-2019, 10:51 PM
Baggergee's Avatar
Baggergee
6th Gear
Looking at specs on bigger amps looks like they池e pushing same or similar wattage per channel. Was thinking of adding 2-channel RF t400x2ad amp to 200L and push about 140W to 8痴 and tweeters with 4 channel. Think I need more power?
Old 03-28-2019, 07:20 AM
Juice's Avatar
Juice
Juice is offline
What bigger amps? 140 is no where near enough for that 8", Hell I have pushed the 6.5 with 300 watts, and they will take 400.
Juice
Old 03-28-2019, 08:27 AM
Baggergee's Avatar
Baggergee
6th Gear
Was looking at this bench test someone posted rating amps and also looked up each amp.
4-channel amps
BT4180 (180W @ 4 ohm; BT claimes unofficial ~220W @ 2ohm)
2 ohm: not measured - see test report for more details
4 ohm: ~150Watt
PPI P4.900 (225W @ 2 ohm)
2 ohm: ~220Watt
4 ohm: ~150Watt
PA RZ4-2000D (specs call out for 250W at 2 ohm, which is complete BS as we all know)
2 ohm: ~140Watt
4 ohm: ~91Watt
NVX NVPA4 (100W @ 2 ohm)
2 ohm: ~107Watt
4 ohm: ~62Watt
SS PN 4.1000D (250W @ 2 ohm; 150W @ 4 ohm)
2 ohm: ~237Watt
4 ohm: ~140Watt
2-channel amps
BT2180 (180W @ 4 ohm; BT claimes unofficial ~220W @ 2ohm)
4 ohm: ~150Watt
RF T400x2 AD (200W at 2 ohm; birthsheet of amp showed 291 at 2 ohm)
2 ohm: ~260Watt
4 ohm: ~150Watt
Old 03-28-2019, 09:22 AM
mike73229's Avatar
mike73229
mike73229 is offline
I ran the mpx coax in the fairing and the SV200.1 and ST 35 in the lids,all off of 4 RF TM channels. Nowhere near loud enough at speed. For me anyway.
Old 03-28-2019, 09:51 AM
Juice's Avatar
Juice
Juice is offline
4-channel amps
4 ohm: ~150Watt
2 ohm: ~220Watt
4 ohm: ~150Watt
2 ohm: ~140Watt
4 ohm: ~91Watt
2 ohm: ~107Watt
4 ohm: ~62Watt
2 ohm: ~237Watt
4 ohm: ~140Watt
2-channel amps
4 ohm: ~150Watt
2 ohm: ~260Watt
4 ohm: ~150Watt
You have your mind made up, go with the RF amp. Your money, your bike.
Juice
Old 03-28-2019, 10:02 AM
Lastride's Avatar
Lastride
Lastride is offline
Juice
What don稚 you like about the RF amps? I知 just learning this stuff as I go.
I知 running a tm400x2 and tm400x4 and it痴 loud and clear rolling down the big road.
Quick Reply: Speaker set up in street glide
