CV B52 and Aquatic AV install
Hey all, I'm installing a Cerwin Vega B52 on my 2013 Streetglide with a Aquatic AV AQ-MP-5BT-H head unit. I previously had a Hogtunes amp that I got for free and I've decided to replace it with the CV. I also have the J&M Rokker speakers in the fairing and will most likely replace these soon as well.
I haven't done anything with audio since I hacked in some subs into my car when I was 16 so forgive me if these are simple questions. The amp was missing the speaker wire plug out of the box (this is being rectified by the local shop I bought it from), but it did have the RCA plug for the inputs. What inputs do I pull from for the RCA into the amp? The head unit uses the factory speaker wires, so do I need to wire in a speaker wire to RCA from the factory wires then plug that into the femal RCAs into the amp? There are a few female RCA's on the amp but one set is for rear outs and the other is audio in, so I'm assuming neither of these will get used since I'm only doing a two speaker set up in the fairing.
Here's a few pics, and of what came in the box (missing the speaker plug wire). If anyone can put me on a path for some baseline settings for this amp I would also appreciate that.
you will need a pair of 18" RCA to connechead unit to amp
the amp output (4 wire plug) will then get wired to your speakers.
I think you will need to Fade head unit fully to rear output as those RCA outputs are rear channel
the blue wire will connect from power antenna lead on head unit to "remote" power on amp
Yea I fully intend to replace them. Any suggestions? My main goal is just good sound quality at highway speeds. Not trying to be the loudest or anything. I'm trying to be cost effective as I've already dumped around $2k into the bike over the winter, but I was looking at maybe Infinity Kappas or Hertz Milli Pros. Any other suggestions?
If you are concerned about keeping marine rated equipment the Polk MM 652s sounded pretty good on my neighbor's bike when I heard them yesterday and they are pretty cost effective.
I haven't heard enough different speakers to say if they sound better than others in it's price range though.
