New bike, new build, new budget
2014 ultra limited looking for recommendations on speakers and second amp.
-Currently have: jl600/6, b3 horns, Sony 5000 HU *Adding 8"lids w/horns *New fairing speakers *Tour pack speakers *second amp *dsp BUDGET $2500 remaining |
Originally Posted by D_Cantelow
(Post 18328164)
:icon_that:
You got a nice budget to make something work well. Just keep in mind the 8" lids will yield a decent midbass but not many choices play well under 80-90hz that work in lids.
-Currently have: jl600/6, b3 horns, Sony 5000 HU *Adding 8"lids w/horns *New fairing speakers *Tour pack speakers *second amp *dsp BUDGET $2500 remaining T |
Thank you T. With a jm amp tray I will be able to get JL amp up front. Will I be able to get a small enough powerhouse to fit as well, or are BT brackets be a must? Any suggestions on a second amp?
(Post 18328872)
I would consider something like this: 600x6- four channels bridged to a set of beymas in your fairing; 2 channels in mono to your tourpack 250.2 - four tweeters GZ mini amp or similar on a BT bridged to two 8's in the lids DD DSI in the cb hole Sony Radio |
I'm on the fly but before u open ur wallet for anything but the BT brackets make sure to be patient and get a bunch of other ideas brother then carefully think thru the amp - speaker wiring strategy. On the flip side u better hurry!! Winter is just around the corner! I have pretty deep family roots in Williston brother. Uncle is a big dawg at XTO. I have a lil retreat just west of Lewis & Clark near the ole Chris Cove. Maybe a cold soda w ya later in the summer?!!! Take ur time brother and use the one and done play book. T |
Originally Posted by Tailwind
(Post 18328964)
I would go w the brackets brother!!! The JL might be able to cover the fairing & some horns and for the lid 8s possibly a SD 600.1 2 ohm or NVX VADM and maybe just grab a SD 250 and get all them horns on that biotch if needed. All that should fit under the hood with the BT brackets.
I would put the 8” on the JL (bridged) and put one of the 6.5” sets (8ohm) in bridge/parallel on the other 2 channels.
© 2024 MH Sub I, LLC dba Internet Brands
