Help with Hertz install in Road Glide Special
The BT4180 is a fine AMP. Although you don't have the ability to control gain and frequency with that particular model. So sound and volume wise you're kind of stuck with what you get when you pair all the various pieces together. I'd say try it first, and if you don't like the results you can always swap out for a different AMP>
Weather resistance is an important consideration regardless of whether the system is powered on when you're riding in the rain or not. Just a thought.................. Really depends on how practical you want the system to be. Are you gonna park your bike every time there's the slightest chance of rain, or try and find cover in the event that you get caught in the rain? I'm not an audiophile enthusiast, just someone who likes to listen to my tunes when I ride. So having any part of my system change my ride plans based on weather just wouldn't be practical for me.
So I just finished cutting the holes in the speaker pods and I noticed that I had to grind down some of the ribs inside as well. Did you have to do this? Also it seems that the lower inside tab on the grille presses into the speaker surrounding. Should I be concerned about this? Using the biketronics wedged Adapters doesn't really work because it seems to push the speaker out more and makes deeper contact with outer area. Btw these sv165.1 do not have a rubber ring around the magnet that a lot of folks mention. Its metal of some sort.
I have the same amount of space between the inner fairing bracket tabs and the Subway for that you have. It's just when you snap the grill and place the male prong makes contact with the speaker
