Wiring help seres or parrellel ?
Old 07-14-2019, 11:04 PM
VIRDOC's Avatar
VIRDOC
VIRDOC is offline
Originally Posted by Dsm Limited
You will want to wire that in stereo, 1 amp channel per speaker. No series or parallel.
Just for my own education.
Why 1 amp channel per speaker for 4 speakers vs the 2 front speakers bridged/parallel on front channels and rear speakers bridged/parallel on rear channels?
Old 07-14-2019, 11:14 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,235 Likes on 999 Posts
That's completely dependent on the amp and speakers in play. It's not uncommon but it's not best for this application.
Old 07-14-2019, 11:34 PM
VIRDOC's Avatar
VIRDOC
VIRDOC is offline
I think I am getting confused because it sounded like the OP had it wired that way in the initial post.
Would it make a differernce if all the speakers were the same vs different front and rears?.
What would be the recommended wiring for a Stinger 700 4 channel amp and 4 Mmats 601 cx 4 ohm (faring and lowers or faring and rear pods)
Just trying to learn.
Thanks.
Old 07-15-2019, 05:38 AM
eggwhite93's Avatar
eggwhite93
eggwhite93 is offline
1 speaker per channel. The Stinger amp is rated at 125W x 4 @ 4 ohms RMS. The MMats speakers are rated at 100W RMS. Therefore wired one speaker per channel the speakers are getting plenty of power.
Old 07-15-2019, 05:43 AM
Dsm Limited's Avatar
Dsm Limited
Dsm Limited is offline
Moderator
Received 8,074 Likes on 2,919 Posts
In this particular combination, I have both of these speakers in play. Neither of these require a ton of power and are pro audio efficent type speaker. I personally would rather not overdrive what's needed. With a little less power these speakers may play a little warmer by being able to cross a liitle lower.
My personal tastes are stereo in the fairing, if possible. Some strategies don't allow for that, but in this case it does.
I have 110w going to the Mmats and 125w to the PRV's.
Another option for the OP that I would consider, is channels 1&2 in stereo to the fairing and 3&4 bridged, parallel to the TP. This gives the rear stage a bit more volume to blend.
paul1970 (07-15-2019)
Old 07-15-2019, 06:47 AM
SBates08's Avatar
SBates08
SBates08 is offline
You can't parallel bridge the 4ohm speakers the OP has already purchased.
Old 07-15-2019, 07:00 AM
Sorce's Avatar
Sorce
Sorce is offline
Bridged is combining channels...or MONO. Personal preference.
It also has to do with power output. Not personal preference.
The only way to sufficiently power the PRV's in an 8ohm version would have been to use the amp bridged and wire them in parallel. Good thing OP has the 4 ohm, (sorry didn't see those!)
You Could wire your Left to amp front and Right to amp rear and use the amp bridged as stereo.
Then you could power one pair of 175Watt rms speakers on that amp in stereo.
Front back left rear is labeled and the fader won't change, but you can wire it however.
Sorce
Old 07-15-2019, 01:47 PM
paul1970's Avatar
paul1970
paul1970 is offline
One more dumb question
am I supposed to cut the rca s off and wire speaker in on that side of amp
Old 07-15-2019, 02:10 PM
SBates08's Avatar
SBates08
SBates08 is offline
If you're running the stock HU, you'll need a PAC SNI-35 to convert your high level (speaker wires from HU) to Low Level (rca). From the PAC you'll run a RCA cable to the amp for input.
Old 07-15-2019, 02:50 PM
paul1970's Avatar
paul1970
paul1970 is offline
Yea I have pac hooked up front channels are working but can’t seem to get sound from the rear
Quick Reply: Wiring help seres or parrellel ?
