DSR-1 tuning (Act #1000)
Ok, I took my bile to a Rockford Fosgate sponsor dealer to get my DSR-1 tuned by a professional as was suggested. Now after the tuning of the DSR-1 I''m a darn good parking lot Dee Jay. I sounds fairly better then before, but when I get out on the highway I have to turn it up to about 40-45 to hear the system. When I DD-1 my amps before the DSR-1 I was at 43 un-distorted, now I can turn the thing to 50 ( which is Max) and hear it some what. My question is , what can I do next to get more out of it? they never touched the amps only the DSR-1. 80.00 down the drain, again. this is what they did
I try to support local shops when I can. What’s frustrating is that most of them don’t even know or understand the specs and features of the products they sell, let alone be able to put it together in a tuned system. Just because they are a dealer doesn’t impress me much since there is a big difference between selling audio and fully understanding it. You have to do research to find the shops that really know bike audio, and unfortunately that comes with a price.
Bflo_SG (07-22-2019)
I agree.
The EQing on that is horrible. I’d ask for your money back. In the meantime I’d set your EQ back to flat and make sure your crossovers are reasonably correct.
Haze knows his stuff. Whomever tuned that must be new. Reset the EQ, put all your "Q" s to 1 so you'll have nice smooth lines when you adjust the hz. Also as haze said, make sure your crossovers are set correctly, meaning look on your spec sheet for your speakers. If it says 100hz to 5khz. You should make sure your speakers is crossed at at the very minimum 100 hz so its not trying to play stuff it's not built to do.
Ikr, crossovers are good. Have to reach out to them. At first I thought it was my source, but when I got my buddy's memory stick it was the same thing .then I tried my phone . So I will start again
