Adding LL's
So, if I were to purchase two BT355's...I assume two, one for front and one for rear channels, could I presumably just install them and not need to adjust anything on my amps? Or is that not possible?
Backstory, I had stinger amp, mmat 601cx in fairing and RK speaker kit in bags done two weeks ago and just had the HU flashed. It sounds great to me, but I want to make sure its a reliable system that I dont have to worry about breaking down on me. Thanks for all the help. |
How is the radio connected to the amp right now? If you dont know the answer to this and you are happy with the sound you have now, I would let it go and be happy with it.
What flash did you have done? Does your radio have the fade option opened up on it? You only need 2 LLs if you will be using/wanting fade. You would need to re-tune the amps if you add the LLs. |
Yes, the gains will need to be set.
Juice |
Main question to answer first is what flash did you have done.
I think this weekend I'll take the fairing off and get some pics of how this thing is set up. I also want to get pictures of where the amp settings are.
I think he used some install bay line out converters, just not exactly what they're for. As far as the flash, I'm not sure there either, but yes I do have fade.. I just keep reading things like not using line levelers might over heat the amp or cause speakers to blow and want to make sure I cover all my bases. |
Originally Posted by teedoff65
(Post 18429357)
I think he used some install bay line out converters, just not exactly what they're for. As far as the flash, I'm not sure there either, but yes I do have fade.. I just keep reading things like not using line levelers might over heat the amp or cause speakers to blow and want to make sure I cover all my bases. So find out just what flash you have as that will determine what you do next. |
Originally Posted by travelingypsye
(Post 18430715)
Originally Posted by marshallb
(Post 18430808)
...X2
I second what Gypse said.
(Post 18430864)
| All times are GMT -5. The time now is 09:57 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
