Question about setting gains
Old Dec 13, 2020 | 01:36 PM
SportySmitty's Avatar
SportySmitty
Default Question about setting gains
I’m setting the gains on a new SD 800.4. I did it with the HP filter on. Does that matter? Thanks
Old Dec 13, 2020 | 05:19 PM
travelingypsye's Avatar
travelingypsye
You want to set your gains in the configuration of how you are going to run the setup. If you don’t have a dd1 then use a voltage meter or fine someone who has a dd1. You can do it the old way by ear also but can leave some on the table. Just make sure to set it at your max volume and don’t go above it when riding.
Old Dec 13, 2020 | 06:58 PM
SportySmitty
I’ll take that to mean that it doesn’t matter if the HP filter is on. I don’t have any Steve Meade equipment, although I have a handheld o-scope coming tomorrow. I hope the cheap Chinese scopes work as they should.
Old Dec 13, 2020 | 07:15 PM
SportySmitty
I put in the SD amp to replace the venerable stinger SPX 700 with two new yellow baskets in the fairing and Mmats coax in the lowers. All brand new. I read that the Stinger didn’t have enough power for the yellow baskets. Maybe I need a better tune but it seems like the Stinger sounds better in my set up.
It seemed like the lower frequencies dropped quite a bit. Is this the reason people are saying to use a DSP with the SD amps? Thanks
Old Dec 13, 2020 | 08:52 PM
SBates08's Avatar
SBates08
You really haven't changed that much as far as power goes. That only puts out 130 watts per channel at 4ohms.
Which 800.4?
Old Dec 13, 2020 | 09:34 PM
SportySmitty
The 4 Ohm one. Should I use both amps? Seems like too much power if I do that. What if I back the gain off a bit?
Old Dec 13, 2020 | 09:39 PM
SportySmitty
What would you do if you had these two amps and speakers? I’ve read this forum for months and still can’t seem to get out of my own way. Thanks for you help.
Old Dec 14, 2020 | 10:28 AM
SBates08's Avatar
SBates08
800.4 Evo, 800.4 Evo S, 800.4 EvoX?
Old Dec 14, 2020 | 01:28 PM
SportySmitty
800.4 EvoX and the Stinger. I found a local shop to have the Rockford flash done next week. Probably going to get a dsp also.
Old Dec 15, 2020 | 08:34 PM
SportySmitty
Has anyone else compared the Stinger 700 to the 800.4 EvoX amp? Seems like a logical comparison. Both are recommended as the simple setup. Without a dsp the Stinger seems to sound better with my setup. I know cshocker did tell me I need a dsp with the EvoX amp.
Da Shadow
Audio Systems
May 8, 2014 03:29 PM
nathanw
Engine Mechanical Topics
Mar 23, 2014 04:04 PM
Ban-One Bail Bonds
May 21, 2013 05:41 PM
RobertIII
Nov 13, 2011 03:45 PM
AdrianVall
Feb 23, 2009 12:39 AM
