Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Audio Systems (https://www.hdforums.com/forum/audio-systems-153/)
-   -   What's the latest word on Ground Zero 6.5" Coax GZCF? (https://www.hdforums.com/forum/audio-systems/1396873-whats-the-latest-word-on-ground-zero-6-5-coax-gzcf.html)
Mr. Freeze Mar 10, 2022 05:41 PM
Originally was going to install a cheap amp and some Polk MM1 speakers in my 14' Ultra Limited. I just installed the Soundstream HDHU head unit, and after going back and forth on amp/speaker combos, I was ready to purchase a Stinger 700.4 amp and the GZs yellow basket coax in the fairing. I found that the bike had stage 1 speakers on it which I was gonna leave them in the tourpack, run the GZ's bridged off the Stinger and run the tourpack stage 1's off the headunits built in 50w amp. Ready to pull the trigger today and while flipping thru some threads, I saw quite a few people have had issues with the GZs. I still plan on getting the Stinger, but am wondering if the GZ's are still having issues. I see a lot of recommendations for them which is why I was gonna buy them. Anybody know if they've fixed/changed anything on them?
Fireball Jack Mar 10, 2022 07:29 PM
A lot of GZ's in bikes, the ones with problems were loud and posted many times. If you are going to run Gz's on a 4 speaker system the stinger is no a good pick. The GZ.s like 200 plus watts. The stinger and 4 Mmats PA601.4cx with the stinger is a very good budget system.
Mr. Freeze Mar 10, 2022 07:34 PM
I would run them in fairing only, with Stinger bridged 2x350W.
travelingypsye Mar 10, 2022 07:53 PM
I wouldnt run them at 350w either. The sweet spot from them is 200-250 and 350 is a bit much in my opinion.
RSmokos Mar 10, 2022 08:03 PM
Watching this thread. Upgrading a 2013 Ultra and bought (4) CS yellow baskets. Almost pulled trigger on Stinger. Thinking two SD EVOX 400.4 but more money. Don't mean to hijack, just watching.
Fireball Jack Mar 10, 2022 08:04 PM
just because you have 350.does not mean you have to use all of it. 200- 250 is where I keep my GZ's and the sound good. With a great tune 300-325 is probably ok but are the gains worth it I am not sure.
scott_0 Mar 10, 2022 09:35 PM
Idk, my GZ's sound pretty damn good with my Stinger, they are after all right in the manufacturer recommended rms rating with the Stinger........
travelingypsye Mar 10, 2022 09:47 PM
Agreed.That’s why I said what I said. I ran mine in the lowers at 200 and had to back down the volume to blend with my fairing.
golfblues Mar 11, 2022 08:17 AM
350 watts, toast! I ran mine at 275 passed around 75hz....they didn't hold up too well after a few hours of riding. I was advised here to run them over 300 high passed at 60hz. Never got the chance.
scott_0 Mar 11, 2022 08:56 AM
Ground Zero clearly they shows their wattage recommendations, but because some guys are dumping 200w rms to them and they last, everyone should do it? then when they blow at double the recommended rms, it's a quality issue??? there are some super knowledgeable members here, no doubt about it, but I can't help but find it funny all the shaming that happens when someone feeds them the manufacturer recommended wattage
© 2026 MH Sub I, LLC dba Internet Brands
