Freq setting with pbr300x2
Old May 20, 2013 | 02:18 PM
kneichko's Avatar
kneichko
Default Freq setting with pbr300x2
I'm doing the same set up as almost everyone else. Pbr300x2 and mm651 speakers on a street glide. Following Nutz turn by turn directions, do you have to set the freq when the amp is set to all pass? All pass it what it should be set at correct?
Old May 20, 2013 | 03:16 PM
rbferg's Avatar
rbferg
No you do not. All pass means the crossover is by-passed altogether and all frequencies are passed to the speaker. If you set to HP, then you need to adjust freq.
Old May 20, 2013 | 07:28 PM
kneichko's Avatar
kneichko
thank you. figured as much but wanted to be sure.
Scooby1426
Audio Systems
13
Jul 11, 2016 12:35 PM
scottiedawg
Audio Systems
24
Dec 25, 2015 09:41 AM
tdgriff
Audio Systems
14
Aug 31, 2014 03:45 PM
keno
Audio Systems
Apr 19, 2014 09:12 AM
springer 03
Audio Systems
Jul 22, 2013 05:44 PM
