View Poll Results: Which Do You Prefer?
SoundStream Amps
14
46.67%
Rockford Fosgate Amps
30.00%
BT 2180 & 4180 Amps
10.00%
Arc Audio Amps
13.33%
Voters: 30. You may not vote on this poll
Which do you prefer? "AMP"
Old Jun 27, 2013 | 09:14 AM
UltraNutZ's Avatar
UltraNutZ
Originally Posted by floridapoolboy
I was worried about the width of the PPI amp, I thought the length was the same as the Soundstream at 9 inches.
PICASSO NANO PN4.320D PN4.520D PN1.450D PN1.650D
RMS Power 4Ω 60x4 100x4 260 400
RMS Power 2Ω 80x4 130x4 450 650
RMS Power 4Ω Bridged 160x2 260x2 - -
Remote Gain Control - - Included Included
Dimensions
(4.75"w x 1.5"h) 7" 9" 8" 9"
Precision i520.4:
http://www.sonicelectronix.com/item_...er-i520.4.html
5.375" W
1.875" H
9.25" L
it's gonna be a tight fit as Chris pointed out...
Old Jun 27, 2013 | 09:22 AM
floridapoolboy's Avatar
floridapoolboy
Originally Posted by UltraNutZ
5.375" W
1.875" H
9.25" L
Damn, Sonic said 9 inches! I'll see when I get in there, it will fit or else!! I guess that's why they made drills and hammers.....!
Old Jun 27, 2013 | 09:36 AM
MontyCop05's Avatar
MontyCop05
Take the following from someone that's been there. I'm all for blazing your own path (when feasible)...but If that AMP is to tight between the fairing supports...don't go at it with a hammer. PLEASE don't go at it with a hammer. If you jack up your inner fairing mounts trying to bend/wrench/tweak etc, you WILL be sorry. You could cost yourself a chitload of money in repairs... Those mounts are pretty sturdy but they are only attached to plastic. You don't want to be running around on a scoot with even one broken support screw...it will compound into many more problems in the long run. Even if the Amp itself can be squeezed in between the supports, but the wiring is going to be kinked or crammed in don't do it. You'll end up breaking the connectors in the amp, on the wiring harness, or causing a rub which will lead to a short etc. Not worth it. If it doesn't fit send it back and wait/watch for someone to get the Soundstream back in stock.
Old Jun 27, 2013 | 09:40 AM
floridapoolboy
Thanks, I was J/K about the hammer! It looks like the PPI is 1/4 inch longer than the S.S. according to Ultra (thanks!), so I hope it's gonna be doable.
Edit: Didn't mean to hijack the thread, I'd vote Soundstream if they were available, RF otherwise.
Old Jun 27, 2013 | 10:08 AM
UltraNutZ's Avatar
UltraNutZ
i don't think you'll have any issues. that SS PN4.520D is longer than the specs state it is by at least 3/4"
Old Jun 27, 2013 | 10:43 AM
Kesean's Avatar
Kesean
None of the above. While they are not bad amps I perfer the JL-HD600 that I currently run.
Old Jun 27, 2013 | 11:36 AM
badazzpred's Avatar
badazzpred
A bit on the pricey side! But definitly a nice amp for a 4 channel. let me ask ya though where did mount it?
Old Jun 27, 2013 | 02:59 PM
UltraNutZ's Avatar
UltraNutZ
some of these are great amps just as the JL Audio is however I think what he was going for was "what fits in the fairing" and the JL 600s dont, either the HD or the XD. The XD 400 fits from what I've seen but even so with some significant modifications to the speedo and tach housings and instruments themselves. Not willing to expose my gauges to moisture for the sake of audio...
Old Jun 27, 2013 | 05:28 PM
UltraNutZ's Avatar
UltraNutZ
the physical dimensional length of the SS 4.520D from end of terminal block to end of RCA jacks is 10.75" add another 3/4" for RCA cable ends and 1/4" for slight room on the terminal block side and you're looking at 11-3/4" total length
so -
10.75" L x 1-3/8" H x 4-7/8" W
Old Jun 27, 2013 | 05:34 PM
floridapoolboy
Hey Nutz, you da man! I was gonna ask if you could measure up an SS amp, thanks. Here's the funny part, the PPI i520.4 I bought measures 10 1/2 inches from the RCA jacks to the end of the terminal block, that's less than the SS! Now I need to check on the width, I know the SS is thinner but the PPI has a tapered case that may help me out.
