Speakers Speakers Speakers
Not sure why I'm making this so hard on myself to make a decision but I just can't seem to make up my mind on what I want to put in the street glide. I had Focal 6x9's in the road king along with Focal coax in the lower fairings. I've been leaning towards doing a component set up this time around but finding it hard to make a decision on what to go with. I'll be running them off a PBR300x4 which is 4 ohms only. I see a lot of folks have the Polk components but those are not 4 ohm speakers. I've been looking at these at crutchfield
Focal Integration IS 165 $179 http://www.crutchfield.com/p_091IS16...65.html?tp=106
Focal Access 165A1 SG $249 http://www.crutchfield.com/p_091165A...SG.html?tp=106
Focal Integration ISS 165 $299 http://www.crutchfield.com/p_091ISS1...65.html?tp=106
I've read most of the speaker threads on here already. Just confused as to what I should do. Heck maybe I'll just through a coax in there and not worry about it.
http://www.sonicelectronix.com/cat_m...-speakers.html
Sonic Electronics has these
The NEW Focal premium speakers are the PC165. Just put a set in my fairing and they sound great. They replaced the CVX 165s. I put a set of the Focal 165A1s in the rear pods, but I had to use a adapter ring as the magnet won't fit in the rear pods without them
Not a Focal fan, at least not of the 'entry level ' stuff....... The PC line is far from their 'Premium' stuff.
Huge difference in sound when you get to the K series stuff. If it wasn't K series or better, I wouldn't buy the Focals. But, unless you want to spend $500 for a set, go with something else.
Dollar for dollar, I think the Polks sound better than the cheap ( less than $500 ), Focals. Some guys just like to see the name FOCAL on that speaker cover, convinced that it is a good speaker. Not so......
FWIW.
FWIW.
FWIW.
FWIW.
I've had great luck with my " main " speakers. I run the Boston Acoustic Pro SE 60's....... Not cheap, but I wanted to build a system once, and be satisfied....
Built this system in early '09........been running 5 summers with no updates......
However, considering the K series Focals for a lowers install.
I personally don't run any Polks,......but I've heard them. Good speaker , for the cheap price.
Good luck in whatever you decide.
