Upgrade 02 to HK
Upgrade 02 to HK
This is not a thread on whether or not it can be done. I have been searching and know I can, I just want to make sure I understand the issues and their solutions. I was hoping those in the know can look over my info to make sure I have it correct.
The bike is an 02 Ultra. As I understand things the basic functions will work (handlebar controls and front speakers) via the 23 pin connector. I loose the CB/intercom and rear speakers. In order to get the rears I would need to replace the current overlay harness due to th different connection for the HK. I could use the non-Ultra harness and gain the rear speakers and connections for add-ons like I-Pod etc... If I use the Ultra harness It would include the CB atenna connection and passenger 7 pin intercom connection along with the rear speakers etc... would need to replace the plug on the interconnect plug from the current three to a six to match the new overlay harness connections. From what I have read I would need to tap into the speedo wiring in order to get the AVC to function. The only issue that I see is needing to be able to "communicate" to the radio. There is no proper routing through the ECM etc... when needing to programm functions on the HK unit unless I were to swap it out for a newer bike and program it that way. Please let me know what I have right or wrong and if there are solutions to the issues or if there is something that I am missing.
As always thanks for the help. This forum rocks!!
Neil
RDMC
Neil
RDMC
some of this is correct info some not.
yes to the 23 pin connector however this is where you AVC is controlled as well. On the new bikes (05-1/2 and up) it's digital. the older it's analog. to switch it from digital to analog simply go into the radio diagnostics and switch it there.
to obtain rear speaker outputs you don't need to go through all the mess and expense of wiring harnesses. You only need to connect 4 wires to pins as follows
These are the pins on the radio itself and they are labeled in the connector
Pin 1 - RR +
Pin 2 - LR +
Pin24 - RR -
Pin 25 - LR -
Now.. if the fader is not activated on the new head unit that presents a whole different issue because then the head unit will need to be connected to an 06 or newer bike for activation. Or you could send it to Iron Cross Audio and they'll activate it for you.
Pin 1 - RR +
Pin 2 - LR +
Pin24 - RR -
Pin 25 - LR -
UltraNutz,
Seems like you are the man in the know; you and Carl (Harleypingman). The only reason I may add the wire harness is to keep the intercom/CB and to be able to add various modules like SAT radio etc... If I do add the harness then I would need to change out the interconnect plug to match the new; yes? Thanks for the reply. Looks like I can start searching for a HK head unit, speakers etc...
Neil
RDMC
Neil
RDMC
UltraNutz,
Neil
RDMC
Neil
RDMC
Everything works. Has the chrome face plate too. I even have the headset given to me when I bought the bike. Never been out of the box.
I will let you know and give you first shot before I put it on eBay or the classifieds. I'm going to start looking for a painter around me to get my LED light bar, saddlebag lids, and speaker grilles painted. If I find somebody that can jump on my project I'll put the bike up for the winter and strip it out.
If replacing the stock light bar with this one, does it get rid of those ugly and unsightly bulges on the inside rear of the tourpak? I'm thinking about (with my new setup) removing the stock tour pak liner and just lining it with stock matching material to finish it out.
Pioneer74.. do you have the LED lightbar with you? What I'd like to know is this;
