The Official 2014 audio upgrade thread
  #2211
Old 04-26-2017, 08:19 PM
FLYINGBROKE's Avatar
FLYINGBROKE
FLYINGBROKE is offline
Wrong thread
  #2212
Old 04-27-2017, 03:52 PM
GlidingJoe's Avatar
GlidingJoe
GlidingJoe is offline
Originally Posted by sponger
I bet the HU just recognizes a voltage chance from bike off to on and thats what changes the bin.
I wonder if you were to remove the Can High wire on the HU, actually remove the pin at the HU connector, and see if the bin file changes. maybe it no longer recognizes the higher voltage due to engine running???
Just a thought
  #2213
Old 04-27-2017, 06:12 PM
BadDadFLTR's Avatar
BadDadFLTR
BadDadFLTR is offline
Sorry wrong thread
  #2214
Old 04-27-2017, 06:15 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
Originally Posted by BadDadFLTR
Looking to advise as to replace this 12 year old relic... it was mounted in the right lower on my new to me electra Glide classic. I have used a Rockford Fosgate in my Road Glide but I'm not up to date as to what's what....
Start a new thread with all your specifics brotha and these guys will provide great assistance catered to your wants and desires.
Don't think u want to get tangled up in this very long thread covering numerous topics.
T
  #2215
Old 04-27-2017, 06:20 PM
HogPilot54's Avatar
HogPilot54
HogPilot54 is offline
Just a thought
Good question! I'll have to look at the shop manual I have for my 15 Limited and see if I can find that wire.
  #2216
Old 07-24-2017, 09:15 PM
sbeamer's Avatar
sbeamer
sbeamer is offline
Do you know who has the best price on the BT's? I think I'm going this route.
  #2217
Old 07-25-2017, 05:29 AM
MMXIWG's Avatar
MMXIWG
MMXIWG is offline
BT currently has a 15% discount on amps and speakers right now if you order from them directly using RALLY as the coupon code at checkout.
  #2218
Old 08-18-2017, 03:35 PM
BDAVEB's Avatar
BDAVEB
BDAVEB is offline
Stage I
Default Going nuts!
I was at Daytona bike week back in March, I had Klock Werks install a new Kicker amp and front fairing speakers and they installed the wiring for easy plug and play for rear speaker lids on my 2014 Street Glide. They left to plugs one is for amplified connection and the other is for non-amplified connection. I have purchased my color matched speaker lids, and I purchased the PS694 kicker speakers for the rear and have them installed in the lids and ready to go. My problem is I do not know where to get the connecter that I need to plug in to the plug that they left for me and the to branch out to the left and right speakers where it connects to the standard flat speaker connection. Does anyone know where I can get this type of harness?
  #2219
Old 09-20-2017, 11:32 AM
brucea4's Avatar
brucea4
brucea4 is offline
Default 2016 CVO info?
Originally Posted by MontyCop05
STAY ON TOPIC PLEASE OR I'LL REMOVE YOUR POSTS - UN
g
I'm creating this thread as a go-to for all of us that are messing with the audio in our 2014 models with the new BOOM BOX stereo system. Please post any knowledge and info gained in reference to the new system. Include what you've tried out, what fits, what doesn't and how you did it. Pictures are a big plus and appreciated. Hopefully this will be a start up guide for those looking to upgrade. I'll start it off.
So I spent about an hour and a quarter on the phone today with Bill over at Biketronics. Bill is a great guy and I learned a lot for him. Wish more companies had guys like him. Anyhow, they have a brand new 2014 limited that they've been hacking away on to set what works, and how. Apparently HD did their homework with the new stereo. It has a DSP (digital sound processor) built in that optimizes the sound output to the (stock) speakers. This DSP is internal and non adjustable. What it does is adjust the equalization and power output to the speakers as you increase the volume. Which is why as you crank it up higher and higher, you actually start loosing volume to clarity. Thus as you approach max volume the DSP tells the radio to push more power to the speakers to fight distortion as opposed to increasing the volume. I've already noticed this effect on my own while riding on the highway.
On this same note, having the internal DSP greatly reduces your ability to just change out speakers to something from the aftermarket. The DSP is precisely tuned to the HD BOOM speakers and the enclosure their in. So if you just throw in some thing else without an AMP behind it, while they might sound ok at first sitting in the garage, they will loose clarity and experience "muddled" low end and "tinny" highs.
Also the new speaker enclosures will effect aftermarket speakers. They are not all that big when it comes to cubic inches of space, and can stifle the response of a good larger aftermarket speaker like a polk MM651 or Titan II. There isn't enough space inside the enclosure to allow for proper response or for the speaker to breathe. The guys are at Biketronics are experimenting with using acoustic vents to fix this issue and trick the speaker into performing like it is in a larger enclosure.
Now when you add an amp to the set up, you will get better response because your getting more power to the speakers, but that DSP will still mess things up. What the guys Biketronics have found, is that when HD does a BOOM system upgrade, they flash the stereo to work with an amp. Apparently there are two different Flashes, one for the BOOM upgrade with the in faring amp for two or four speakers, and the 2nd for the CVO setup. I'm told these flash updates really help when adding aftermarket speakers and an amp. What I'm going to have to find out is wether my dealer will flash my stereo for use with an amp even thought I'm not going to be using their BOOM crap.
Now for those interested in the Biketronics products (like me), their Titan II 6.5 inch speakers will fit in the stock fairing enclosures with very little modification. The little plastic "locating" nub for the stock speakers on the outside of the enclosure needs to be cut off. Then you'll need to get a countersinking drill bit and drill out the holes in the Biketronics mounting ring to the point where the mounting screws lay flush. Thats it.
Bill also told me that filling the front speaker pods with lose polyfill really improves speaker response. Especially on the low end. He was quite surprised how well it worked in these new pods.
As for the rear pods, the Titan II's will also fit, but you'll need a thin spacer ring.
Note:Biketronics doesn't recommend installing their speakers in the new bike without an amp behind them. The combination of the DSP and power output of the stock 6.5 BOOM BOX really hampers the ability of these speakers to perform as they should.
As I posted in another thread, the Polk MM651's will also fit in the front/rear of the 2014's, however you need to do the same countersinking measure with the screws on the polks up front as well.
I'm considering going with full set up using all Biketronics gear. Two sets of Titan II's, and their BT4180 amp. The amp is quite pricey but its also quite impressive. And with a lifetime warranty, I'm considering trying it out. If I don't think its worth the money, I'll send it back. However if I do this install, I take plenty of pics and post a full review/tutorial here in the audio section.
Look forward to seeing what the rest of you come up with. Hope this long winded post helps some of you to get on your way with your upgrade.
Good info! Thanks for the details. Now, I have a 2016 CVO Limited and would like better sound at highway speeds without breaking the bank nor voiding my extended warranty!
  #2220
Old 09-21-2017, 09:48 AM
MMXIWG's Avatar
MMXIWG
MMXIWG is offline
bruce this thread has a lot of dated information and doesn't get used much anymore. Great reading if you follow itallthe way through to the end but there are a lot of new components hitting the sled audio scene. I strongly recommend you start a new thread (if you haven't already) and give everyone your budget, existing setup, desired number of speakers and listening goals i.e. parking lot queen, riding down the highway at 80 mph and type of music you listen too.
Rick
brucea4 (09-21-2017)
Quick Reply: The Official 2014 audio upgrade thread
