Aerocharger Fuel Pump Question
Hi,
Unfortunately my Aerocharger kit did not come with a fuel pump. I have purchased a small generic unit, but am now having doubts that it's going to be able to provide enough pressure. I have the supplied Aerocharger rising rate pressure regulator - a Mallory unit so thats okay.
I am running a Carbby setup with a Khein CV unit (tweaked with the Aerocharger supplied bits)
Can someone let me know what brand and model fuel pump your running with your setup? I think I'll play it safe and just buy the proper one.
Cheers
Cheers
i have three units at the shop and will look at the pumps but i do beleave they are low presure unit for carbs.even on my pro gas racer we used a low one and regulate the return for it does not take muck to fill the smaller bowls to muce and they run gas into the intake. the pumps were from aerocharger
Thanks for that. Half my problem is that i have no idea of the boost settinsg for my Aerocharger. I was planning on 5-6 PSI and so bought a 10 PSI pump, but if the unit puts out 11 PSI of boost then I'm going to be in trouble.
I have all the plumbing done so retro fitting another type of pump will not be an issue.
GR
GR
