Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Hard starting when warm
Old 04-17-2017, 07:08 PM
ractrev's Avatar
ractrev
ractrev is offline
What he said! My MM injected bike had the map under the side cover, when I swapped it to the carb, I put the same sensor into the intake like the picture above.
  #42
Old 04-17-2017, 08:09 PM
Road Star's Avatar
Road Star
Road Star is offline
  #43
Old 09-04-2017, 04:45 PM
Road Star's Avatar
Road Star
Changed the pilot to a 45 and the main to 195. Surprised at how much the low end performance increased. Very noticeable change. I think I'll keep it there for a while and see how she does.
  #44
Old 03-29-2024, 01:29 AM
Jjcouch139's Avatar
Jjcouch139
Jjcouch139 is offline
Stage II
I know this is a really old post but did changing the jets fix your problem? I have In 03 Road King and having the same problem when it is warm. The motor was rebuilt last year with 584 cams. I'm not sure about the other details, only that it at 107 now rather than 88. But I'm still running the same cv40 as before with no changes. So what was the final outcome on your bike?
  #45
Old 03-29-2024, 01:42 AM
Road Star's Avatar
Road Star
To be honest, I don’t remember the exact details, however, pretty sure the larger jets helped. Shortly after this post I picked up a 2018 RGS.
  #46
Old 03-29-2024, 09:11 AM
Jjcouch139's Avatar
Jjcouch139
Stage II
Thanks. I'm having issues starting after short stops. I'll try changing the jets and see if that works.
  #47
Old 03-29-2024, 10:47 AM
Road Star's Avatar
Road Star
Well, if it is a bigger displacement plus cams, that will definitely require larger jets. Might be a good idea to check everything in the carb. Get a good rebuild kit and make sure the float is adjusted properly. Good chance it does need a larger main jet. Needle settings could be critical too.
  #48
Old 04-08-2024, 09:00 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,808 Likes on 3,313 Posts
@Jjcouch139
You should start your own thread.. You'll get more responses that way.. Also about over to the newbie thread and say hello (New Members)
For starters though with a built 107"er, I would get at the least a CV44 or a Mikuni 45 or even an S&S G..
avetter11
01-20-2012 07:15 PM
MGN54
11-07-2010 07:00 AM
dalemcf1
Custom Models
07-24-2007 01:16 PM
stilllearning
Exhaust System Topics
04-03-2006 01:54 PM
raaaaaa
06-20-2005 02:30 AM
Quick Reply: Hard starting when warm
