You can mod the vacuum petcock so it operates like a conventional non vacuum petcock. Google will tell you how. I would do that for at least diagnostic purposes. YD
Best is to replace the EPA petcock with a manual one and just remember to shut the fuel off.
A drawback to the vac operated fuel valve is at high throttle settings the fuel shuts off from lack of vac.
I've had a vacuum operated petcock on Reaper since day one (first the OEM then, a few years ago, I installed a Pingel), and have had her at WOT PLENTY of times. She NEVER starved for fuel due to a lack of vacuum shutting the petcock off.
One can also just replace it with a traditional petcock and plug the vacuum line.
