Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
new guy-backfiring & loss of power
Old 04-24-2017, 01:49 PM
chanceparker's Avatar
chanceparker
chanceparker is offline
Stage I
Question new guy-backfiring & loss of power
99 FXD 88c.i. carbuerated, stage 1 air cleaner, no other mods.
when i twist the throttle hard, it wants to bog down for a full second, maybe 2, then jump RPMs, enough to jerk me back on bike.
when i'm decelerating, its backfires thru the exhaust.
Ive ran a can of carb cleaner thru, plugs are brand new NGK, and wires are in good shape.
where do I go from here?
Old 04-24-2017, 02:03 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,538 Likes on 3,790 Posts
Welcome from Hampton Roads Virginia. If it is lean and sounds like it is, either the accelerator pump is not pumping a shot of fuel or your jets are stopped up. Running carb cleaner thru diluted with fuel does little to nothing. And do not even think of running it straight since it will destroy the rubber and such in carb. A decelerating backfires thru the exhaust if the exhaust is open and you let the throttle back too fast is pretty normal. You may need to go thru carb.
Old 04-26-2017, 04:17 AM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is offline
Received 1,734 Likes on 928 Posts
I agree, time to pull out the carb and clean the jets and all the passage ways. Old gas?, bike sitting along time with old gas? If so, jets probably clogged. Especially the small holes in the low speed jet and the small holes on the emulsion tube. YD
OneHarleyAtATime
EVO
45
09-23-2021 07:56 AM
Tileman2692
11-28-2017 08:11 PM
OneHarleyAtATime
Carburetor Related
06-11-2017 05:09 PM
terrapin88
04-06-2010 11:17 AM
Chopster1200
10-04-2009 08:28 PM
Quick Reply: new guy-backfiring & loss of power
