Trying to tune up a '95 WG
#42
Maybe I'm jumping the gun because I haven't checked the timing or changed anything on the ignition, but the mixture screw still does nothing on my ride. I've got the idle running smoothly 900-1000rpm. The bike starts immediately and runs pretty well I think. The spark plugs are nearly identical in color, with the rear just slightly richer (not like before when it was black and white difference).
The only thing I have not confirmed or resolved is a possible manifold leak. Last I tested, I thought both front and rear were bogging down with carb cleaner, but I could have been overspraying it. Will test again.
#44
#45
If you had a manifold leak, adjust the idle mixture screw in all the way would kill the motor... However the fact that any adjustments to the idle mixture screw still makes no difference says that there is still something wrong. Your sucking fuel from somewhere....
#46
I'd go back to the 42 pilot. Earlier you stated that when turning the Idle mixture screw in all the way (lightly seated) you could see it sticking through the hole... I'm not 100% sure that it should protrude into the venturi.... It is known that if the needle is screwed in to far (closed) it could do damage to the carb and I would imagine that it would totally affect the idle circuit where the port in the carb body would be to big and would allow for more fuel than normal.... Also I'm wondering if there is a main jet air bleed and if that is the correct size? just trying to help...
#47
I've ordered a 42 pilot and a new float valve, so we'll see what that does. I haven't ordered a replacement mixture screw because I can't see anything wrong with mine. I would be surprised that the screw entering the venturi would cause a permanent problem. I understand your theory on the needle boring out the port if someone cranked down on the mixture screw.
What do you mean by a main jet "air bleed"? Maybe I've overlooked this.
#48
