Just replaced vacuum petcock with manual one carb is pouring gas (not just leaking) out of top left orifice could this be related
Where the arrows point is spot it's pouring from
I'm wondering if you don't have a blockage of some sort farther down the inlet line somewhere, and where it's leaking, is the easiest path for the gas to escape from.
Ty so much I unhooked one hose and she stopped lol prolly ain't hooking that thing back up
Float height adjusted properly? Float sticking? If bowl is overfilling fuel will leak out of that passage. After looking at that pic, the cracked and dry rotted fuel line should be replaced.
