Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
No Fuel Flow
Old 09-14-2017, 05:00 PM
roussfam's Avatar
roussfam
roussfam is online now
Received 6,718 Likes on 3,494 Posts
Default No Fuel Flow
I had the tank off of my wifes 06 Carbureted Sportster 1200 Low, now bike wont start. No gas coming out of the petcock.
The only way I can get gas to flow is to blow compressed air into the bottom of the petcock. When I do that it runs out pretty good, I reconnect it real fast, but it seems to stop? Float bowl is empty. I can get it to run by squirting gas into the throat of the carb but that's it.
EDIT: I guess my next step will be to disconnect the fuel line at the carb, blow air into it until it starts to run and hope it fills the float bowl. Makes me wonder what would have happened if she had ran dry on the road? Full tank, but wont flow.
Old 09-14-2017, 05:04 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,901 Likes on 3,012 Posts
Drain the gas and remove the petcock, sounds like the screen/filter is clogged or it's not turning inside.
They sell rebuild kits for a reason.
Old 09-14-2017, 05:09 PM
roussfam's Avatar
roussfam
It's odd though, had no problems what so ever, disconnected fuel line and vent hose to remove tank, reinstalled tank and no go. Probably pull it and have a look this weekend.
Stupid question, should it flow out by gravity? Service manual talks about using a vacuum pump to create suction.
Old 09-14-2017, 05:23 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Could be a part of the plastic that determines Run or Reserve broke off and is stuck just above the shut off portion. If your blowing in air it might just move enough but won't clear as the top of the petcock has a screen, so it'll just fall back down.
Old 09-14-2017, 05:27 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Does yours have the vacuum port? If so check the hose (not the fuel line) coming from the carb for suction.
Old 09-14-2017, 05:31 PM
Lakerat's Avatar
Lakerat
Lakerat is offline
Sounds like a vacuum controlled petcock that isn't hooked up.
Old 09-14-2017, 05:39 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Lakerat, that's what I'm thinking. See post #5
Old 09-14-2017, 05:46 PM
roussfam's Avatar
roussfam
That's what it was, hose vacuum hose came off the back of the petcock....all good now.
Thanks guys....Jim
Anixon88
Exhaust System Topics
16
07-27-2022 06:17 PM
Whitey1
EVO
20
07-27-2022 09:04 AM
just plain john
EVO
17
04-20-2018 11:45 AM
1 Beat Up HOG
10-13-2007 10:54 PM
Sally88
07-15-2006 05:30 PM
Quick Reply: No Fuel Flow
